The metadata of van Zweden’s Bruckner 8 seems to include a review of Simone Young’s Bruckner 8
I think (you’ve not filled out the metadata support template) that your album is actually identified as the Simone Young recording. In this instance, I would suggest a manual re-identification. The following search terms should get you the correct album as the top hit:
- Artist: “Netherlands Radio Philharmonic Orchestra / Jaap Van Zweden”
- Album: “Bruckner: Symphony No. 8”
thanks, @joel
I had previously re-identified the album as the van Zweden one, but the Simone Young review remained. Miraculously, tonight (about 2 days after I reidentified), the correct review was there. Seems to be the magic work of the metadata improver
Sometimes what happens is that TiVo assigns a release to the wrong album (release group) which pulls two albums together incorrectly. Then it gets fixed, but it takes a while to filter through. Not saying that’s what happened in this case, but it seems plausible.
