Hi all,
I want to try HQPlayer embedded with Roon.
Actually I got it all set-up, but can’t get the Volume Control in Roon Work.
HQplayer zone always shows up as “Volume Control is Fixed”.
Thanks for any help / advice.
Best Jin
Hi all,
Best Jin
This depends on HQPlayer Embedded volume control settings. Please check that you don’t have a fixed volume set in HQPlayer Embedded configuration.
