Hi all
I got soemnew Sotm gear but having problems getting it to play. The device volume is set to 0 max and I can’t seem to change it. Sms 200 is connected in Eunhasu and Roon has found the device and seems to be playing music just the device volume level is zero and every time I try to change it resets back to zero.The green light on the front blinks sometimes and is solid other times. The ethernet lights are blinking.
Any help please.
Sean
