I use 3 ropieee pi´s this HAT´s from hifiberry.
Since the update to the newest ropieee version one of my berries put the volume back to zero by itself after every try to put the volume to any level…
This is a pie with the DAC2 HD HAT from hifiberry. The settings are the same on all my pie´s.
Yes, unfortunately this is an issue with that DAC in combination with the latest stable Linux kernel.
As long as Hifiberry does not fix this there’s nothing I can do. I’m monitoring this, but so far no progress whatsoever.
This issue is just happening on the hifiberry DAC2 HD. What would hifi berry have to do? Because the hardware will be the same, and there is no driver to be installed - just ropieee…?
No. There is a driver involved, which is part of the Linux kernel. And they need to maintain it.
I don’t know. They will probably run into this when they release their own distro with the updated kernel.
For now it doesn’t make sense (at least for me) to contact them: they’ve shown on multiple occasions that they don’t care about support for other OS’ses then their own.
I just installed the latest hifiberry os - resulting in the same issue.
So I wrote to the hifiberry support… I hope they will update their software soon… no musik in my kitchen! Cooking without music is not acceptable
I will report here if I got an answer from hifiberry.
I got answer from hifiberry…
well. The answer was, that they dont support hifiberryOS via the support plattform, just through their community.
So I went over to their communitiy…
There i found a thread already describing this issue - and the answer from the hifiberry team: If you think this is a bug you can open a tread at…
At some point I’ll update to the latest Hi Fi Berry OS as you did (I have a spare SD card) - and if I can reproduce it I’ll raise on github as he’s suggested. I have an account so it’s not too hard…
Curious if Ropieee plans to support the InnoMaker Raspberry Pi HiFi DAC HAT?
About 80% of what’s on the Ropieee hardware list is obsolete, not many options on there are obtainable, especially if you are tied to RCA jack outputs.
The innoMaker seems readily available.
Thanks for consideration.
