Hi,
my library is 90% Tidal and 10% local files.
The Tidal are mixed normal and MQA (while I own a non-MQA dac) and my local files are all Replaygained.
The Volume Leveling is at “Auto”, -23LUPS, -5dB.
Is simply don’t work good to me.
The songs jump in volume very much, I have Always need to use the remote to adjust volume if I listen to a playlist…
Why that happen? Why in foobar (Replaygain) I don’t have the same issue?
For what I understand, Roon treats differently Tidal, Tidal MQA and Replaygain volume songs…
