Hi all!
Have a great problem after a (automatic) update to firmware version 4.0.0 on my Auralic Aries Femto. My situation: I go from the Auralic Aries Femto direct (digital) into my kii three loudspeaker using the ROON volume control.
Since the firmware update ROON always starts with 100% (full) volume. That’s a big risk for the health of my speaker!
Is it a ROON problem or a firmware problem? Made no changes in the settings (firmware and ROON).
AFAIK (I’m not using any software volume control, only did a test when the issue was brought up on CA) there was a problem with volume control in the last 4.0 beta: as soon as you hit “play” volume set in Roon was always reverting to whatever it was set to in Lightning DS
Here is the answer i got from Auralic:
Thanks for report back, we will try to resolve the problem in next firmware release.
Xuanqian Wang | CEO & Designer | support@auralic.com
Got no answer form my question if ther is a way to go back to vers. 3.3
