Volume: Procedural EQ vs. Headroom Management?
For volume adjustments, is there any difference in using Headroom Management vs. Procedural EQ? I’m running a convolution filter and trying to set the right volume adjustment to avoid clipping, and noticed I can do it in either way, so curious if it makes any difference. Seems like you can set either way and still have it remembered as a preset.
