Vorbis comment CATALOGID not showing up
Hi guys, I tried doing a search but could not find anything related to displaying CATALOGID from my flac files. I use MP3TAG to populate the CATALOGID field from DISCOGS which I assume corresponds to Catalog # in Roon. However, when I edit my album to prefer file data, nothing is displayed. Any ideas whats happening?
Roon will read catalog numbers from CATALOGNUMBER.
Have a look here:
https://kb.roonlabs.com/File_Tag_Best_Practice
Thank you for this. I went ahead and mapped in mp3tag CATALOGID to CATALOGNUMBER and its still not showing up in Roon. Roon says that field is empty though I can verify its there.
Have you checked the tag’s written properly to the file? MediaInfo is a good tool to check.
Roon does read the tag if it’s there - I’m sure about it. Here’s an example:
Which gives me this:
have a try with “LABELNO” then … .works for me.
But CATALOGNUMBER should work aswell.
