@DeLub if you read the Sonos forum post I linked to you’ll see that since update 7.2 the new Flac library internal to the speakers can handle 24 bit files.
It’s unofficial but was curious if Roon has a configuration file I can edit and force 24 bit instead of 16 to my Sonos devices. Just out of curiosity.
From the post I learn mostly that this is an unsupported side effect from version 7.2 and that the forum members are wondering wether the extra 8 bits contain something else than “junk”.
But you’re right that Sonos apparently accepts 24 bit files. The question is: would this lead to increased SQ.
I cannot answer your question though: I’m not aware of a config file that can be hacked.
When I updated my sonos controller app on android last night I noticed there was an item in the settings menu that I never noticed previously.
The option was for audio compression. It was greyed out so I was unable to go in to the menu without doing a firmware update on all my sonos devices so I never bothered at the time but I will have to have a look when I get home tonight.
Ah right OK. I was excited at first but I only use the sonos playbase in the living room for the TV and use the play 5 in the kitchen when cooking so I don’t do any critical listening.
Just want this to work out. Sonos only does 24 bit from local, not from streaming. Roon is both local and streaming, but seems Iike it ought to be able to “spoof” being local, but maybe that’s a pipe dream.
This is a known behavior since Roon (build 831):
“Implemented support for streaming 24-bit audio content to Sonos device running “S2” Gen firmware”.
For S2 Sonos devices Roon plays 24bit in principle (local, Qobuz, TIDAL), even if the source is only 16bit.
If I play local media or Tidal with no DSP or Headroom enabled I get 16/44. But it depends on the source material as well (unless sample rate conversion is turned on (at least with Tidal and local))
It Surprised me as I responded and did some extra testing.
Worthwhile as I learned something as I have been looking at this for a couple of weeks and it finally clicked what was happening
