Does anybody know what antenna connectors fit the motherboard? I have bought U.FL to RP-SMA and I have just discovered that U.FL do not fit. I suspect the right ones are MHF-4. Can anyone confirm please? The motherboard uses the Wireless card Intel Dual-Band AC 8265.
A quick Google says the MHF 4 is correct. It also says a lot of people have made the same error based on misleading “people who bought this also bought” type links.
Good, I have just ordered them. I will confirm when they are delivered, to the community’s benefit.
