So far i havent been able to set up my roon streaming [via android end point]. My core is wired on my LAN and my android devices are connected to my local wireless. Can i stream from the core to the endpoints even though they are wired vs wireless?
Yes, you can.
Yes you can as long as they see one another and use the same address range.
Cheers for the response guys, the issue I’m having now that I’ve kind of got it working, on my phone [lgv40] it has the phone as the output, but on my tablet [samsung s6] it doesnt have that option and only works as a remote rather than an endpoint. Any idea why the two android devices work differently?
