Xtr Filters - Why do they sound so good?
Will your new DAC accept higher DSD rates than 128?
I will perhaps in a few weeks get the Phison preamp with the new dac card also based on ESS9028 PRO and that will accept DSD 512 over usb.
Your impressions regarding DSD from Roon is something that sounds really intresting as I asume Roon upsampling to higher dsd rates is less demanding on the computer than HQ Player?
No just DSD128, which is fine as I use a SOTM sMS-200 and only DOP DSD128 will work with a maximum 384KHz pcm rate.
Yes, Roon is less intensive. I’m not sure if it’s ESS9028 that likes the Roon’s DSD7 CLANS modulator or the analog implementation after.
You’ll have to play with it and see what you like.
I will see if my computer can deal with DSD512 and if I will buy some endpoint just to test this as I dont own any endpoint right now.
@andybob Did you try the xtr filters doing PCM first or just went straight back to roon?
I’m doing some xtr pcm to 352/384 pcm right now with dsd64 being passed straight through. Gives me the xtr magic but with the pcm punch.
Hi Jeff,
Firstly, I think you are right about attack with PCM. I used the term weight because I hear it most in the mid-bass, but it is the leading edge that we are both talking about…
I have listened now for good long periods upsampling Redbook to:
  1. DSD 512 (8 x 48), xtr 2s, AMSDM 512 fs+ in HQP
  2. PCM 384, xtr, NS5 in HQP
  3. PCM 352/384, Precise Linear, 7th Order CLANS in Roon.
These are all linear phase filters and the first surprise for me was that I generally preferred linear phase over minimal phase. I do like minimal phase for tuned percussion (Chinese gongs, vibraphone etc.), but otherwise I find the soundstage more focussed with linear phase.
The second surprise was that I like long filters. Xtr are the longest that HQP does and some of the longest you will find outside a Chord. I don’t appear to be troubled by pre-ringing and I suspect that I like the euphonious thickness of ringing generally. Long filters enable steeper band rejection and it seems that I prefer ringing to higher leakage of ultrasound.
In terms of comparison, I tend to leave it on one of the above for lengthy periods of time rather than change it around. I think, however, that each is suited to different material as follows:
  1. is my current setting (again). This has the best detail and expansive open soundstage but it loses some impact on the attack. It’s not my favourite for classical or percussion for those reasons. I like it for serious listening to most modern music, female vocals and especially for acoustic guitar (which seems counterintuitive, but there you go);
  2. is good for classical and percussion ā€œlisteningā€. Better attack, slightly narrower and more forward soundstage;
  3. is more like a ā€œparty modeā€. Good for pumping dance music, male vocals, upsampling internet radio and when playing background music socially. It may be that others would be happier with a shorter minimal phase filter for those tasks, but you can only take so much of my soundstage away before I get quite bolshie.
Edit: Also thanks very much for linking the Dustin Foreman article in this post.. I think it’s the best explanation of filters that I’ve read.
DSD vs PCM. DSD is thicker, slightly less precise and more relaxed for me, but I’m only working working with DSD128. PCM seems more detailed to me but that could just be more high end energy. PCM sound stage is more precise and everything has more punch and impact.
I’m going to stick with PCM->PCM via HQPlayer for a few days and see how I get accustomed to it.
Very interesting discussion. Until I got my new system dialled in I preferred upsampling to DSD 512 in HQ Player. I liked the smooth analogue sound.
However now that my new system has finished burning in (with some new NOS tubes) I prefer upsampling PCM to PCM384K using poly sinc xtr (when upsampling to DSD512 I am limited to the -2s poly sinc filters due to my PC)
Both options sound amazing - I just prefer the extra bite staying with PCM and the xtr filter.
But in a harsher/brighter system I could easily imagine preferring DSD. I suspect the best solution is system dependent.
Should also have added that the soundstaging is quite different - vocals are much more forward with PCM than DSD
I like the sound of the poly-sinc-txt filters very much, but I noticed I would experience frequent dropouts or extended periods of silence with those filters engaged whenever my VPN (Netshade) was active.
No problems at all when the VPN is off.
The xtr filter is 5 times more cpu intensive than normal poly-sinc.
I used the xtr filters, both for pcm and dsd (128). I play from audiolinux to microrendu to lampizator amber.
Usually I was satisfied about the sound, apart from high and forte string passages in classical music. The strings seem to have a sort of phasing sound. Of course this phasing effect is naturally due to the different intonation of the players, but I felt it as more than normal.
Yesterday I experimented with the FIR , the MinringFIR and minringfirmp filter. For PCM I used the gauss1 as dither and upsample to 88.2.
Are these FIR and minringFIR filters actually okay. They sound better and more transparent in my ears. And the phasing sound of the strings seems more into natural proportion.
Does anyone use these filters, I dont’read anything about them.
I have certainly seen users comment that they prefer the minring FIR filter. If you imagine a notional scale in HQP with (short, minimal ringing, shallower cutoff) at one end and (long, ringing, steeper cutoff) at the other then the minring FIR filters are towards the short end (polynomial is shortest) and the XTR filters are at the long end.
A shorter filter with less ringing yields a higher fidelity transient response. A steeper cutoff pushes out of bandwidth noise (antialias or DSD artifacts) lower which I believe results in better preservation of spatial cues. So ringing is the price we pay for steeper cutoff filters.
The HQP filter palette has a wide variety of different compromises between the various constraints imposed by mathematics. I understand Jussi listens to poly-sinc-mp as his preferred filter. There isn’t a lot of writing about the sound of the filters because people are still discovering what they like and are hesitant to give opinions. There are no musically right or wrong filters, just different compromises. Similarly to speakers. Sometimes people prefer a euphonious sound to fidelity, I suspect I am one of them.
Thanks for the insight about a phasing sound in the forte strings. I think this could be a consequence of ringing.
Isn’t minRingFIRmp the filter miska says is closest to Ayres internal filter implementation? If so many love it.
One of the better explanations on Digitial Filters is Charles Hansen’s white paper at Ayre
http://www.ayre.com/white_papers/Ayre_MP_White_Paper.pdf
Thanks Nikhil, that was a very interesting paper, including as to the origin of the word ā€œapodisingā€ in relation to digital filters.
What it doesn’t show is the increased extent to which anti-aliasing artefacts get through with the slower roll off.
Even though no one has posted here for awhile, I have actually read this a few times recently for ideas on HQP filters.
FWIW, I just upgraded the firmware on my Lampi Atlantic (or, i should say Lampi did) so that it could play DSD 512 with my Microrendu. Using the same xtr-2 filter that i had used in 128, the sound was initially very exciting, but then quickly turned very fatiguing. Very. It seemed like the ringing created by that filter was more audible. Gave me quite the headache.
So, that got me playing around with the filters. I am currently spending time with the minringFIR. I am really impressed. Amazing separation between instruments and vocals, very natural sounding, great presence and quite punchy. All without the fatigue.
Give it a try.
Thanks everyone for all the great helpful posts.
Thanks John,
Another vote for minringFIR. I will give it another listen.
At the moment I’ve been taking a holiday from DSD and listening to PCM 768 using the xtr filter which I find quite enjoyable. However I’ve also been mainly listening ā€œon the goā€ while doing something else in another part of my apartment (cooking, cleaning, reading etc.) so I will have to sit down and compare things properly. Maybe I will end up with different configurations according to what I am doing.
Hi John,
Sorry to be OT, but i’m interested in your feedback playing DSD512 on LAMPI Atlantic from MicroRendu (Linux powered).
I’m using DSD512 native enabled DAC (T+A DAC8 DSD) but unable to play DSD512 due to current Amanero USB driver / firmware limitations (on Linux).
Some questions:
  • Is your LAMPI using upgraded AMANERO USB chipset firmware ?
  • Do you know AMANERO FW version (possibly from MicroRendu WEB GUI or directly from Linux command line) ?
  • Any audio issue like high pitched whine or chirping sound when playing DSD streams or changing tracks ?
Thank you for you feedback, i like HQP minringFIR too …
Volpone. Just last Friday, Amanero released the combo384 firmware update that permits use of Linux NAA to play DSD 256 and 512. No issues whatsoever with the update, has played glitch free since last Saturday.
Thank’s John.
Any link where upgraded AMANERO COMBO 384 firmware release is announced / available ?
