24/96 and higher MQA tracks do not decode correctly using internal MQA decoder
Hi, this is something I’ve been wondering myself but I’m not sure if I know which setting you are referring to. I have the setting for “How would you like Roon to treat MQA encoded content?” as “Treat MQA as better than CD quality, but not as good as lossless hi-res content.” Is this what you are referring to?
No in services area where you link your Tidal account ensure the streaming quality is set to Master. For the endpoints in the audio settings for each zone ensure you set Roons MQA core decoder to on and MQA capabilities is set to Decoder Only.
Finally, that was it. I still had the default setting for Tidal under services so I changed that to Master. I hadn’t noticed since I mostly listen to my local library files and Qobuz but got Tidal as well since they have the most content. Glad to have figured this out - thank you!
