5 minutes to load a single track since 2.0 Build 1211
Roon will analyse a file for level etc normally these will be <200 Mb, so presenting a 8gb file may be the cause . it may simply run out of resources for such a big file . You could try turning analysis off , see if that helps.
My biggest files are possibly 500Mb , a symphony movement in 24/192 so I have never approached any limit. Mostly mine are 44.1 or 96 with a very few 192
the Logs will no doubt show this when the support guys get around to analysing them.
@Mike_O_Neill , I’ve had the analysis stuff in Library shut off. This doesn’t stop Roon from continuing its attempt to slowly add additional tracks.
Let’s see. 20 hours ago, Roon had identified 270 of 28K remaining tracks. Here’s where we are now, 20 hours later:
1,000! Yikes, that’s a mere 36.5 tracks an hour, with audio analysis shut off. JCR
I know you know , but that’s not right :stuck_out_tongue_winking_eye:
Roon is calling home to mama for ID so once again it points to network. Either yours or theirs.
I added 3 albums say 30 tracks in probably a minute, that,s right
Have you checked DNS Settings, I am not an expert on that , but it looks like You to Roon has a disconnect?
I am still a bit concerned over the massive file size, I have not seen another user with such a collection, I could be wrong.
@support should comment on such files in your logs
Not a lot of help :cry:
Geez this is really unfortunate situation - do you have “Background Audio Analysis” turned off? Also, are the drives holding the music files internal or external USB connected to core?
Hello, @Swisstrips. I do have background and on demand audio analysis turned off. These drives are externals, connected by USB3.0 to the Roon core server. I did have my NAS connected via Ethernet and was having the same issues, which is where this all started. So, after I had backed up the entire NAS to the external drives — that took some time with 43Tb of data, about 40Tb of which are my music files — I disconnected the NAS from Roon and pointed my music folders in Roon to the external drives. This was to prove up that the adding music to library issue wasn’t because of my NAS being slow on I/O, it being a Synology 1813+ with an older, smaller processor. The experiment to me demonstrates a Roon bug.
@Mike_O_Neill , I’m not sure what I would be looking for in DNS settings. I can tell you that I have Gb internet streaming and no issues with network connectivity for any other situation on the Roon core server or otherwise at our home. JCR
If you have 4 USB external drives , have you tried disabling 3 of them , leaving just one as a watched folder. Settings> Storage Theoretically a USB controller will work with 4 external drives (up to 127 devices !!) but you will obviously suffer on speed USB is slow relative to SATA
I assume these are externally powered USB HDD like Seagate/ WD etc.if not the power will be shared too.
Use the 3 Dots to Disable each one.
Its worth a try , I have run 2 external drives in the past but normally a singled one
Also if you go to Settings>Storage what do you see ? Certainly on ROCK as you start up it will rescan all external USB drives , but NOT the internal Drives that means all 48tb , that will be slow. On mine the USB drive shows 67134 but at startup that starts from 0 and rescans to the number , maybe check that . You could be spending resources rescanning drives
I wonder if you are asking too much of USB
I added internal drives to my Windows PC so they were SATA connections . My PC has a gaming mother board just to give me more SATA points than a normal MB. I have 1 SSD and 4 HDD internally. (Audio and Video)
Depending on how handy you are you can extract the HDD from the USB housing and mount it within the PC chassis and connect by SATA. If my suspicions are correct.
@Mike_O_Neill , this was an interesting experiment. I sequentially disabled the USB drives so that I could see what might happen if only one of them was active. With drives 1 and 3, the adding music to library is complete. If only drives 1 and 3 (and their corresponding folders) are active, the spinning semicircle is gone from the Roon home page and tracks, albums, searches and playback all occur quickly. These two drives account for 159,452 of 278K total tracks.
Drive 2 is where the action is at. It has 27K of tracks that Roon is trying to import at below snail’s pace speed. Roon stops functioning, for all intents and purposes, if only Drive 2 is enabled, clearly because of the importing issue.
To close the rest of the loop on your comments, the external drives are actually internal drives that are running in an externally powered docking station. This test, however, suggests that installing the drives internally would make no difference, just as using my NAS via ethernet still has the same issues.
So Roon obviously doesn’t like something on Drive 2, which is probably the same thing that is on the NAS. I want Drive 2’s content, of course, which is for albums with artists G-R and includes 600 of my 1,400 multichannel/Dolby Atmos albums.
This leads to the next experiment. I have identified a series of folders on Drive 2 that hold mainly old mp3 files which, frankly, I don’t listen to (but they are helpful to find a corresponding TIDAL album). I’m copying those folders off to Drive 4, which has always been disabled from Roon. Once the copying is complete, I will start deleting the folders sequentially from Drive 2 to see if one of them is the big holdup. JCR
I wait with baited breath :smiling_imp:
Ok, @Mike_O_Neill. I can now report back on where I am at now.
Having pulled a batch of older mp3 out of hard drive 2, I seem to have gotten the music adding to library to stop. So, I went back to my Synology NAS and moved the same set of files out of my watched folder. This led Roon to do a full rescan of my NAS watched “Music” folder under new production build 1223.
The result:
All is working fine off the NAS!
Is this due to Roon getting hung up on some the tracks I moved out of the watch folder, just simply because of a fresh scan because the old database was corrupt or something to do with build 1223 over prior versions? I don’t know….
But now, what is the 16,137 track difference between what Roon reports as imported and the number of tracks on the home page? I ask because, for example, my 8 channel version of John Williams’ Berlin Concert no longer appears in my library, even after a forced rescan. Before I started down this odyssey, that album was available. (It sounds really good.)
I also note that Roon garbled the track ordering for Toto IV and has separated the versions of albums in many cases. For example:
Why is this not appearing as a single album with multiple versions? I’m not looking forward to fixing this all through my 200K+ tracks.! Thanks. JCR
About the Let it Be: What is your setting for Settings > General > Show hidden tracks and albums? Set it to No if you want album versions grouped. If yes, each version is displayed separately
Ah, @Suedkiez . My bad for not saying earlier that show hidden tracks and albums is indeed shut off, which is why I am asking how to fix, short of manually going through my entire library. JCR
Oh OK, I thought that must be it because it seems weird to me that you seem to have so many that are not auto-grouped, but no idea why.
Roon will auto group Let It Be’s if the Album Name tag is Let It Be in each case with no additional text, maybe post a snapshot of the file folders …
If in your folder you have a structure “Let it Be [Super Deluxe]”., “Let it Be [Version 2]” anything in [Version] after the title will be interpreted as the Version. You can also use a Custom Tag [Version]
If your Album folder are anything else Roon will treat them as separate albums eg "Let it Be - Some Descriptor "
Its the same with Box Sets if you have a box with 10 CD’s nd the folders are named CD1, CD2 and they all have a common Album Name Roon will group them as a Box. If the album folders contain more than CD1 eg CD! - Abbey Road Roon will see each folder as a separate album and try to ID accordingly
It Sounds like you’re on the right track though
Hi @Mike_O_Neill . Ok, got that.
Can you help with the example album, the John Williams 8 channel Berlin concert? It’s in the same watched folder on the NAS that it has always been, yet Roon won’t recognize it. JCR
https://musicbrainz.org/release-group/67637867-9e4b-430c-8094-a6db13af9f74
But its not showing a multi media 8.1 version. Roon is only as good as its data sources. Discogs shows much the same as a 2 CD set
It’s the digital media source. As earlier noted, Roon properly recognized and played the album for me until the new scan of my entire library.
For comparison, this 8 channel recording of Stravinsky is recognized by Roon, even though it does not appear in MusicBrainz as an 8 channel recording:
https://musicbrainz.org/release-group/4b4e7801-cb16-3589-8769-1443e8749db6
And here is how it appears in Roon:
When Roon doesn’t recognize my 8 channel recordings, they still appear anyway, just without the full metadata:
So why doesn’t the John Williams Berlin Concert show up in one way or the other? The Olympic theme in Dolby Atmos is one of my favorite demonstration tracks. JCR
Hi @Jeffrey_Robbins,
Please allow me to ask about the current status.
So the problem with endlessly adding music to the library (see 5 minutes to load a single track since 2.0 Build 1211 - #47 by Jeffrey_Robbins) is solved for you and everything is working as it should? The overall responsiveness of the Roon system etc. is also fine?
I have noted that Roon has released an update Roon 2.0.12 and ARC 1.0.33 are live! - #3. Can we please assume that this update fixes the problems described?
Thank you
