Advice on hardware for running RoonOS (ref#OVG9TN)
I want advice on what i should purchase to run roonOS
Starlink
Your question is not really one for the Support team (who are there to address technical issues and problems with Roon), so I’ve moved it from the Support category to the ROCK category of the forum. Community members will likely respond with their suggestions for their favoured devices to run RoonOS that is installed by ROCK.
If you want to choose a device that is fully supported by Roon Labs, then pick a device from the list given here:
Or if you want a “plug and play” device rather than a DIY project, pick one of the Nucleus models:
https://roon.app/en/nucleus
BTW, your decision will also be influenced by factors such as the size of your library (local plus streamed content), the number of simultaneous Zones you want to have, and whether you will be using Muse.
See here:
