Roon Core runs on an MacBook Pro 2013, version 1.8 build 756.
Ethernet
Meridian 210 (ethernet, works fine), several MacBook Pro (wifi, work fine), several Sonos (One, play3, play5, connected via Sonos Boost(ethernet)), iPads and iPhones (work fine, wifi)
Other then the MacBook Pro and the meridian 210 all other devices are gone and can not be found. Before the upgrade everything worked fine. Tried to connect the core via wifi, no difference. After reading the posts in the community, I tried several restarts, no difference. What to try next?
Since 1.8, my Sonos still shows up as a device but it won’t play - just keeps saying Roon lost control of this device. Everything else works fine. Tried restarting Roon, NUC, network, Sonos… nothing works.
Graeme, thanks for the replay. Tonight I resetted my compete system (includig the Sonos devices). Now they are back in the Roons system. I cannot explain the error or the recovery now, but happy everything works again. Thanks. And so far happy with 1.8!
