Apple Mac Mini 2011 RoonV1.8 latest
Netgear Switch hardwired to renderers
B&O Essence x 2 - Airplay over hard wired ethernet
My system was completely operational until I installed V1.8 a few days ago, since when I have been unable to control control the volume of both my B&O Essence devices using the Roon volume control. I can use the B&O remote to change the volume. Roon is set to use “Device Volume” and has worked perfectly until the upgrade. I have tried using the volume control on the Core, and Remote on Ipad, Iphone & two PCs.
I have several other B&O Core Chromecast renderers which the Roon volume control remains functional with.
I also have a pair of Beolab 50s which I normally set to “device volume” for best quality - but they do also seem to function OK with the Roon Volume control.
