Allo digione and Audio Alchemy DDP1 problem
Room core over win 10. Allo digione signeture runs over diet pi
Using coax input to audio alchemy ddp1
Hi.
Just got a this very good DAC/pre-amp. When playing through Roon with Digione as an end point to feed the Audio Alchemy coax input I hear a short out of sync click from the Audio Alchemy.
Any idea how to try to solve this?
With my Hegel H90 there is no problem. I tried both coax input without any luck…
Have you tried adding Resync Delay under Device Settings?
From the Knowledge Base:
Resync Delay
This setting is primarily used when an S/PDIF, AES, or I2S connection is involved. Oftentimes, a DAC will take a little bit of time to lock onto a new audio signal–sometimes as long as a few seconds.
This setting causes Roon to play a configurable duration of silence whenever it begins a new stream. Like the last setting, this one is a problem solver. If you find that the beginnings of songs are being cut off, or you’re getting a lot of clicks and pops while your DAC locks on to an S/PDIF signal at the start of playback, try increasing this setting. 500ms is a good starting point. If that doesn’t work, try gradually increasing it from there.
We default this to a very small value because it produces delays in Roon’s user experience. Consider that when setting it up–unless you have an uncommonly slow DAC, settings longer than 1-2 seconds are probably not necessary.
I tried to play with this a little, but the problem is not in the start of every song, but in the middle…
Hi @Roi_Peretz,
Is there any pattern to types of media affected by this issue? Does this only occur with high-resolution content? Specific file formats?
If you plug in the Audio Alchemy to the Core via USB, temporarily bypassing the Digione, does it display the same behavior?
Hi!
I don’t see any pattern. It occurs with every types of files and resolution and the pattern is random.
I tried to plug the as using the USB connection but the ddp-1 isn’t recognize by the computer.
Hi @Roi_Peretz,
Can you please share a screenshot of your Roon Settings -> Audio tab with the DDP1 plugged in via USB? This screen should look similar to the following:
Hi @Roi_Peretz,
Have you made sure to install the Audio Alchemy driver? Instructions on how to do so can be found on the DDP-1 Manual, linked here on page 7. I would also make sure that you have the USB input selected on the DAC itself.
Tried to do both, but I couldn’t install the driver because it says that the device is not connected.
Hi @Roi_Peretz,
I would try a different USB cable. If you are unable to install the driver outside of Roon, this could indicate a communications issue between your PC and the DAC.
