Can you recommend some alternatives to Sonos? Sonos is basically unusable for me: the wifi connection is too unstable and unreliable. The speaker at just 3 metres (10 feet) from the router and with nothing in between keeps getting disconnected; the one upstairs often doesn’t show up at all, while from the very same spot I can stream HD video from a tablet with no issues. This happens even when I use the Sonos app so it’s not a Roon issue.
I am based in Europe. My wishlist is:
multi-room like Sonos (I should be able to play different stuff in different rooms)
works with Roon but should also be able to play music on my NAS, from Tidal and from internet radio independently of Roon (I don’t want a system that’s unusable should Roon go out of business/shut down)
can be controlled from Android phones and tablets; ideally from a PC, too
I am not after audiophile-level quality and prices – something in a similar price range as Sonos would be great
The stability of the wifi connection and of the Android app are more important than pure audio quality
Must be able to work without internet. Sonos works when your WiFi doesn’t have internet access – chromecast speakers don’t.
Must work with wifi but ideally have ethernet as a backup
I have read a lot about HiFiBerry used to stream audio, but it’s not clear to me if that supports multiroom, nor how the practicality of installing it would work – having speaker plus HiFiBerry would be a bit of an eyesore.
I have read contradicting feedback on Kef and Bluesound.
Thoughts / suggestions?
