M1 Mac mini
Netgear switch GS724T Router TP Link Archer VR2800
Hugo 2
9509
I cannot connect to using ARC on my iPhone, I get the following message in the diagnostics data window:
“ipv4_connectivity”: {“status”:“NetworkError”,“status_code”:502,“error”:“error: Error: connect EHOSTUNREACH 46.aaa.bbb.ccc:55002, response code: undefined, body: undefined”},
“external_ip”: {“actual_external_ip”:“46.aaa.bbb.ccc”,“actual_external_ipv6”:“null”,“router_external_ip”:“46.aaa.bbb.ccc”},
“upnp_autoconfig”: {“server_ip”:“192.168.1.1”,“found_upnp”:true}
Does anyone know what the problem is please?
What country are you in and what is your internet provider?
Hi Ged, I’m in the UK and the provider is EE, thanks.
Is it normal broadband or a SIM 5G type connection?
If it’s broadband then this might help
Hi @India_Kirby ,
I’ve merged your post into a dedicated topic thread where we can more directly support you. Thank you for bringing your issue to the attention of the Roon Community. We’d be happy to help out.
I first recommend you follow the steps suggested very helpfully by @Ratbert , as they’ll likely resolve the situation entirely; it appears he sent you a PM with additional information. Thanks @Ratbert for assisting there.
In general, you need to correctly configure the rule in the EE gat…
Hi Ged, Many thanks for your reply, I am on conventional wired broadband, not 5G my router is a TP Link Archer VR2800 and not an EE router. Hope this helps.
Have you forwarded the port using this guide?
Hi Ged, I have set up the core as a static IP and open a port as the instructions you forwarded, and it has all worked. Many thanks for your time and help. Regards, Bruce.
That’s great. Enjoy mobility
system
(system)
Closed
June 6, 2023, 5:35pm
9
