Previously deaf user working on discovering music here. (I got a cochlear implant.
Quick question - to increase bass in equalizer is it as simple as pulling up the low end as i did in my attached picture.
Thanks very much!
Thanks very much!
It is but you need to apply headroom in Muse also as you will get clipping with any boosts in the bass region. I would set it to be the same amount as your boosting to start with and adjust further if it indicates itβs still clipping, in arc it will show where it shows the current signal path state.
I got homework! ![]()
Thanks very much @Simon_Arnold3 - much appreciate your taking the time and a (very) clear answer. Cheers ~P
