Networking Gear & Setup Details Nucleus+, ORBIRBR850 w/1 Satellite over Ethernet.
No.-
Who is your internet service provider? Spectrum
Please list the make and model of your modem and router? DOCSIS 3.1 Modem; ORBI RBR850 w/1 Satellite
Do you have any additional network hardware, like additional routers or managed switches? No managed switches, but three unmanaged ones.
Does your network have any VPNs, proxy servers, or enterprise-grade security? No.
Everything is playing over Airplay(2, presumably). Two streaming speakers, (Bose soundbar, Oppo streaming speaker), one Oppo Network Streaming DAC connected to primary sound system.Description of Issue -
What is the exact port forwarding error message you see in the Roon Settings → ARC tab?
{"connectivity": {"status":"NetworkError","status_code":502,"error":"error: Error: connect EHOSTUNREACH 76.aaa.bbb.ccc:55002, response code: undefined, body: undefined"},
"external_ip": {"actual_external_ip":"76.aaa.bbb.ccc","actual_external_ipv6":"2603:8000:d800:12c7:56b2:3ff:fef0:e7fb","router_external_ip":"null"},
"natpmp_autoconfig": {"status":"NotFound"},
"upnp_autoconfig": {"server_ip":"192.168.1.1","found_upnp":true,"error":"<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns=\"urn:schemas-upnp-org:control-1-0\"><errorCode>501</errorCode><errorDescription>ActionFailed</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>"}
For lack of a better word, the connection appears to be unstable. One day, Roon indicates that its connection with ARC is ready; then, when I actually intend to travel someplace, nothing, usually, happens and I am faced with a "no connection" message. It has worked a couple of times, but, that is rare.
