Ubuntu 22.04.1 LTS
Manufacturer: ASUSTeK COMPUTER INC. Product Name: E35M1-I
AMD E-350 Processor
8GB memory
Ubiquiti Dream router. Roon opening Arc port via upnp
NAD M33
Bluesound PowerNode N330
11274
I have problems using Arc on Android 12 (On OnePlus 10 Pro)
When I choose to play something it takes a long time and I would always eventually get the “Poor connection” message
Arc settings when using roon remote tells me all is ok. And I can connect just fine from the Arc app over 5g
I made a test yesterday. Choosing a track in AAC format streamed fine while choosing a track in flac format (most of my library) only results in the “poor connection” message
So it seems the problems has something to do with transcoding flac to the format you automatically choose for Arc (is it 320bps MP3?..I don’t remember)
While my room core is not the fastest it can transcode flac to 320bps mp3 with 11x realtime speed. So I really don’t understand why it shouldn’t be fast enough for Arc
Hope we can get this solved so I can be as happy an Arc user as I am a roon user
BR
Hasse
