Rhein Z1 Plus
Firmware Version: VitOS-1.2.5311
Memory: 32GB
IP Address: 192.168.1.75
Roon Server: Version 2.0 (build 1392) production
Router: Fritz!Box 4060
WAN connected
Internet, IPv4
FRITZ!Box uses a direct IP-connection with a internetprovider
IPv4-adres: 100.106.55.23
Internet, IPv6 not connected
USED DNS-servers
62.45.70.102 (Currently used for standard applications)
62.45.71.102
110,486 tracks
Hi, team Roon,
I had Roon Arc working up until October 2023 as far as I can recall. At some time it stopped working. Don’t no what caused it.
I don’t get Roon ARC running again ‚over the Internet in my network setup. I use the default port, 55000. First, I shared that port on my router manually. After that didn’t work, I followed these instructions: Port Forwarding Instructions for (Most) Fritz!Box Users 9. Listening Port 55000 appears automatically, but stil Roon Arc is not ready for use.
I restarted Rhein Z1 Plus
I restarted Roon server
I deactivated UPnP and reactivated it again.
I restarted de router.
Nothing seems to work.
I always get these diagnostics:
“ipv4_connectivity”: {“status”:“NetworkError”,“status_code”:504,“error”:“error: Error: ETIMEDOUT, response code: undefined, body: undefined connected? undefined”},
“external_ip”: {“actual_external_ip”:“62.ddd.eee.fff”,“actual_external_ipv6”:“null”,“router_external_ip”:“100.aaa.bbb.ccc”},
“status”: “status”: MultipleNatFound
“upnp_autoconfig”: {“server_ip”:“192.168.1.1”,“found_upnp”:true}
Hopefully, you can make anything out of the diagnostics.
