Asus RT-AX88U w/ mesh extender. Everything except Vizio soundbar (Chromecast), Sonos ERA 100 and mobile devices hardwired. No VPN.
PCs (2), hardwired
Vizio soundbar - Chromecast
Sonos ERA 100, Galaxy phones, iPad - Wi-Fi
Hyundai Tucson, Android Auto, Roon ARC – Cellular with port forwarding on the router
6,000 tracks
Running ARC in Android Auto. The volume level from ARC is much lower than other streaming sources. I have to increase the volume level for ARC, but if I forget to turn it back down when I switch to another streaming source I get blasted.
Volume leveling is enabled by default in ARC, which tends to lower the volume overall. Or maybe you have MUSE DSP settings enabled with headroom management as well?
(Although IIRC the Tidal app also has had leveling enabled by default for a very long time)
The default is not -5db that’s for music where it’s unknown. By default Roon applies levelling based on the EBU R128 measurement of loudness this is 14 LUFS by default. The amount it will reduce or increase volume will vary on content based on this.
It seems to make sense to me that when being mobile or in the car, the albums are leveled to a common peak loudness. (This does not change the loudness within a song or within an album - it’s not compression, i.e., it normalizes loudness not volume as such)
(Note: the documentation does not yet ARC / MUSE into account)
