Still no update on this issue ?, wasn’t solved in the latest (greatest ;-(( ) roon update.
Regards,
Edwin.
Regards,
Edwin.
Hi @Edwin_Muskee,
I understand your frustration as this issue has lingered for some time at this point. The ticket is still with our development team, but progress is slow. I wish I had more information to share, but unfortunately, there haven’t been any updates shared with our team yet.
Until they are able to spend more time on this issue, I recommend pausing Roon Server when making any edits to prevent crashing.
Can we move this on, its been in the queue for ages. I suffer exaclty same issue as OP. I also know it affects othes as well.
I’ll guess it’s still in the que, hasn’t been solved in the latest/greatest bunch of updates since reporting this.
Is this ticket with development still alive and sitting in the que?
Also discovered something from tailing the log of roonserver. When I change a folder name in my music storage roon discovers this. It starts analysing these ‘new’ files and concludes:
05/13 21:49:05 Trace: [music/searchindex] totals: 7403 albums, 120744 tracks, 46098 works, 71943 performers, 2282 labels, 1514 genres
05/13 21:49:05 Trace: [analysis] Track Joanna Wang - Start From Here - The Best Mistake I've Ever Made was found in AudioAnalysis API, updating Track...
05/13 21:49:05 Trace: [analysis] canceling analysis
05/13 21:49:05 Trace: [identification] album changed out from under us. aborting identification (in _SpinQueue)
05/13 21:49:05 Debug: [easyhttp] [19450] POST to https://api.roonlabs.net/identifier/identifier/2/album?tidal=max returned after 455 ms, status code: 200, request body size: 5 KB
05/13 21:49:05 Debug: [identification] <1810223> status: Identified
Ok, so far one would guess, But then out of nothing:
5/13 21:49:06 Trace: [dbperf] flush 0 bytes, 0 ops in 11 ms (cumulative 3201294382 bytes, 1536161 ops in 242696 ms)
05/13 21:49:06 Trace: [metadatasvc] GOT [9231] (170ms) Sooloos.Msg.Metadata.GetMetadataResponse:
05/13 21:49:06 Trace: [metadatasvc] GOT [9230] (392ms) Sooloos.Msg.Metadata.GetMetadataResponse:
05/13 21:49:06 Trace: [library/compute] computing 17 / 17 tracks
05/13 21:49:06 Trace: [dbperf] flush 349493 bytes, 291 ops in 9 ms (cumulative 3201643875 bytes, 1536452 ops in 242705 ms)
05/13 21:49:06 Trace: [library] finished with 3566 dirty tracks 210 dirty albums 1651 dirty performers 2197 dirty works 2859 dirty performances 192 dirty genres 1 dirty places 179 dirty folders 0 clumping tracks, 0 clumping auxfiles 17 compute tracks, 0 deleted tracks, 17 tracks to (re)load, 0 tracks to retain, 0 auxfiles to (re)load, 0 auxfiles to retain, and 8249 changed objects
05/13 21:49:06 Info: [importstatus] notifying 17 imports completed
05/13 21:49:06 Trace: [identification] <2088239> Identifying album [Talisha Karrer - Acoustic Covers 2] with 12 tracks
05/13 21:49:06 Info: [library/albumdetails] found 1 ingroup alternates, 0 other alternates
05/13 21:49:06 Trace: [music/searchindex] [search-index] removed in 0ms: 1 albums, 17 tracks, 3 works, 22 performers, 0 labels, 57 genres
05/13 21:49:06 Trace: [dbperf] flush 0 bytes, 0 ops in 4 ms (cumulative 3201643875 bytes, 1536452 ops in 242709 ms)
05/13 21:49:06 Trace: [library] endmutation in 370ms
05/13 21:49:06 Trace: [music/searchindex] [search-index] added in 9ms: 1 albums, 17 tracks, 13 works, 38 performers, 0 labels, 57 genres
05/13 21:49:06 Trace: [music/searchindex] totals: 7403 albums, 120744 tracks, 46108 works, 71959 performers, 2282 labels, 1514 genres
05/13 21:49:06 Trace: [dbperf] flush 0 bytes, 0 ops in 6 ms (cumulative 3201643875 bytes, 1536452 ops in 242715 ms)
05/13 21:49:07 Debug: [easyhttp] [19453] POST to https://api.roonlabs.net/identifier/identifier/2/album?tidal=max returned after 300 ms, status code: 200, request body size: 4 KB
05/13 21:49:07 Debug: [identification] <2088239> status: CouldNotIdentify
05/13 21:49:07 Trace: [identification] <5649967> Identifying album [Madison Hughes - Renditions] with 9 tracks
Roon finds some new albums which were allready in my library, and are not new at all. Why is the big question??? Talisha Karrer album is imported in july 2021… which is around 3 years ago…
Hopefully someone from @support can help me and some others with the same problem (see the forum) …
Regards,
Edwin.
@benjamin , is this ticket still in the que or did someone hide it in a cosy dark spot…
I still have the audioanalyse stuck feature when I simply change a folder name on the storage watched/used by roon
Regards,
Edwin.
Hi @Edwin_Muskee ,
I wanted to check in with you here since I was tidying up open threads, are you still able to reproduce this behavior on the current Roon release, or has the issue subsided? Looking over the case notes, we tried to reproduce in the QA lab but could not, so please confirm, thanks!
Yes, easily. Just copy a folder to storage watched by roon. NAS or local doesn’t matter. Rename the folder after the copy has finished and audio-analyse stays spinning with a couple of files left for days. I’m also not the only one experiencing this. Stopping/starting roon solves it or just turning audioanalyse off/on.
