Audio Device Connection Lost After Idle (ref#95T3FS)
· The System Output has *no problem*, it's only my other Zone.
· Network - Ethernet
· Sonos
· Yes, it shows up there, but it isn't Enabled
Does the "Enable" button unlock the Zone?
· I pressed Enable, but the Zone remains disabled
· It happens all the time
· Sonos, Apple, Wiim. Ethernet wired
Everything is correctly connected but when trying to play music O have a message that says Roon has lost connections with the audio device. If I restart Roon Server I am able to play music but after a few minutes in idle, the issue cames back.
Roon Server runs on a dedicated Max Mini M1 with latest macOS 15.4.1. This Mini also runs Plex Server but I have zero issue with Plex. Everything is connected through Ethernet. I also own multiple Sonos devices and Airplay devices.
Hi @Joao_Paulo_Florencio,
Thank you for your report. Are you experiencing these issues with Airplay, another protocol (like Sonos itself), or a mix of different audio/connection protocols? The simplest way to answer this question would be to share the details or a screenshot of the Signal Path in Roon in the configuration with which you experience these lost device errors.
In the meantime, we’ll activate diagnostics for RoonServer to automatically upload logs to our servers. Our team will inspect these closely to determine what RoonServer has logged as the cause of the dropout. We’ll follow up with recommendations or next steps.
Please leave RoonServer running on the Mac Mini for at least a few minutes so the log reports can reach our servers. Thanks!
HI
I have the same problem Today, Sonos doesn’t work via Sonos streaming. But it works with Airplay2.
Roon lost control of the audio device…
I had no problems yesterday.
Thank you
