And what about the problem with Roon’s erratic behaviour with audio devices? Has this been noted?
Hey @Arne_Dielis,
Thanks for asking about this.
If you’re referring to the issue where only 10 audio devices can be enabled in Settings → Audio? Our team is working on a fix, but, in the meantime, using less than 10 audio devices should work.
If I’m missing your point, would you please let me know?
Thanks for replying. I only wish it was possible to enable 10 devices, but alas… I can enable 7 devices and use them like before. But upon enabling the 8th device, Roon goes all epileptic with the devices, rendering them inaccessible to other apps such as Tidal, even crashing 2 of my Sony Chromecast speakers. They only came back online after hard resetting them. What a hot mess. Was this even tested before release. One does wonder…
Hey @Arne_Dielis,
Thanks for your candor
I’m hoping it won’t be the case that Roon goes all epileptic (this gave me such a good laugh ) again. I can’t wait for the fix to be released
Hey @Arne_Dielis,
Could you please update your Core to the latest build (882)?
It was just released and it should resolve this issue:
