Rock 1.8 (build 1105)
Running on Cirrus7 with Intel DQ77KB Motherboard with an Intel Core i7-3770T processor
1TB Library stored on 2TB Samsung T7 Touch connected via USB
Roon core connected via Ethernet to Huawei b525s-23a router connected via Ethernet to Sonore Microrendu
Wired connection from router to Sonore Microrendu, connected to Denafrips Ares II DAC via USB.
Wired connection from router to SOTM-SMS200 connected to Chord 2Qute DAC
21,000 tracks
I recently purchased a new Core to run ROCK on my system (Cirrus7 with Intel DQ77KB Motherboard with an Intel Core i7-3770T processor).
I am now frequently experiencing " Audio file is loading slowly- this may indicate a performance or hardware problem" with any file in 88/24 or higher resolutions (I can never play more that 15-20 seconds of a 192/24 file).
I can play just fine MQA 192kHz files from Tidal (and have only rarely had problems playing 352kHz MQA files).
I tried playing 352/24 files by connecting headphones to the Cirrus7 core, and they play just fine.
What is puzzling is that whenever I use my old system (same ROCK version running on an Intel NUC6i3SYH, same network configuration, same endpoints), I can play without any problem 352/24 files stored on its internal 2TB Samsung 860 SSD.
The problem is fully reproducible when switching back and forth between cores (de-authorizing the other one every time, of course). The discrepancy (issues with Cirrus7 but not NUC) is seen with any of the endpoints I use, whether they are connected via Ethernet or via WiFi.
The LEDs on the Ethernet connector of the Cyrrus6 show that the 1000Mb/s data rate is selected.
Any idea why the i7-based Cirrus7 is experiencing performance issues and not the i3-based NUC?
