Audio playback issue due to missing codec (ref#TCJ8PP)
· Something else
to the install codec requiered audio codec missing
impossible to use it after installation
Hi @surghjenti5,
Could you provide the details of your Roon setup and how it is connected to your network.
I’m assuming you have a ROCK installation on a NUC, is this correct?
If so, have you followed this guide?
https://help.roonlabs.com/portal/en/kb/articles/roon-os-missing-codecs#Background
Hi @surghjenti5,
Thanks for reaching out to us to ask about this. The questions @Carl asked are a good start. Once you let us know this information we can begin troubleshooting your missing codec issue.
· Something else
impossible to know how install caodes no way 100 try and nothing its good ur explications are confuse cause we nee screen or video tutorial
i need help for codecs
Did you follow the directions found here
One tricky point is that the downlowded file should be unzipped several times.
This looks like a Windows error dialog to me.
And here especially:
NOTE: If you use a Windows N version or similar then exactly those codecs are missing tough. Use Microsoft’s instructions to install those codecs anyway (and thereby transforming your N version into a regular one I guess). Look here: windows media feature pack - Google Search
I have merged duplicate threads and the responses into the original thread. Please do not recreate threads. Official support is Mon - Fri, so please be patient over the weekend.
Hey @surghjenti5,
You’ve got some excellent next steps listed above from @Rugby and @BlackJack, were you able to review them yet?
Thanks! :raised_hands:
