Music is stored on a Synology HDD attached to home network.
I’m also using Tidal.
Playback is via Sonos.
93,000
Message ‘Roon lost control of the audio device’ appears briefly, then music starts. Play button doesn’t change to Pause. Time remains on 00:00. After about 30 secs track starts skipping, then stops. If I press Play again it skips badly from the beginning.
Thanks for your suggestions. Unfortunately my PC and router are in different rooms so I’m stuck with a WiFi connection. I’ve tried all the basic troubleshooting ideas. I’ve just bought a new router which might help. But since changing the router Roon won’t play via Sonos at all. I can see Sonos Connect in the Roon Audio section but nothing happens when I press play. Any suggestions would be appreciated!
Check your router to see if there is a better channel to select for the WiFi?
I use WiFi analyzer to check signal strength.
Might be able to move things around to improve the signal?
I also had a drastic improvement when I went to eero pro mesh network.
It helped my endpoints. But I made my Roon core wired.
