MacBook MacOS 10.15.7 Roon 1.8 build 756
Ethernet connection to ADSL router from Proximus
Cambridge Audio CX61 directly connected through USB cable to Roon server on MacBook
Since the update to 1.8, whenever I stop the music for a while, I can’t use the audio zone corresponding to my Cambridge Audio amp directly connected to my computer. The amp is defined as a zone, but it does not appear in the zones I can choose to stream music. When I go to the audio zones settings panel, it is in the list with a little gear next to it. The only option is to choose to disable it, if I do that I can then hit the enable button, but then I get back to the gear with no possibility to use it.
After restarting Roon, everything is back to normal, but this is annoying.
