I’ve had numerous email exchanges with Peter in the past with regards to the DMP-1 suddenly disappearing from my network when playing Roon via USB. It behaves like a memory leak. I don’t get the issue using I2S. Prior to the latest update I’d not had the issue for a while but since the latest update I’m getting it frequently (after a hour or so of play time).
Thanks. You may need to leave it playing for a few hours. The issue presents itself at an indeterminate amount of playing time. But the symptoms are that the music stops and the DMP disappears as a Roon endpoint. The only way to recover is to reboot the DMP and then do the MPD/Roon shuffle through the DMP admin UI to get the endpoint back in Roon.
No problems after a couple hours of playback last night. I was playing mostly DSD-64 files and Tidal. Here is a screenshot of my DMP-1 settings with firmware version.
Now that being said, I am in the process of comparing USB vs. i2s and will figure out which sounds better to me.
See this thread I created:
I will fire up the DMP-1 over USB for the next 8hrs. I’m in the other room though so its not constantly monitored. If music stops, I will notice of course. Will report back findings later tonight.
It’s definitely not a corrupt file as it happens on completely different tracks. I don’t also see how it can be network as I’ve been playing via I2S from the same NAS for well over 24hrs non stop now.
I know from previous email exchanges with Peter at AA there were memory leak issues before with the USB playback and the symptoms are identical.
I need to check if we’re running the same versions.
