Auralic Aeries S1 Shuttering with Roon possible Shairport Sync issue
Hi, when streaming with Roon to the Auralic Aeries S1 the music is shuttering, crackling in an awful sort of way. Streaming via Qobuz and Lighting DS (auralic’s streaming streaming software) the music sounds terrific.
When I first set up said streamer and linked it to Roon. Roon recognized two devices for the one said streamer. These were Auralic Aeries Mini and Auralic Aeries S1 (Shairport Sync). I used the Auralic Aeries Mini as my endpoint because the Auralic Aeries S1 (Shairport Sync) cut out, shuttered, and crackled. The Auralic Aeries Mini endpoint sounded terrific. Today I turned on the system and both endpoints are Auralic Aeries S1 (Shairport Sync) and the music is unlistenable. Auralic Aeries Mini has disappeared or been replaced with another Auralic Aeries S1 (Shairport Sync). Please help me fix this problem.
:point_right: Get Help With Roon
This helps our team gather all the necessary information to solve your issue as quickly as possible. Thank you!
Hello @Joosttx ,
Thanks for reaching out with your message! For us to be able to better assist you, can we kindly ask that you resubmit a proper support ticket by filling out the questionnaire using the below link? Please select the option that best matches your specific issue type instead of simply selecting “other”, as this form was created to help diagnose issues while gathering information and it will allow the support team to be able to best assist with your specific issue type. Thank you!
https://account.roon.app/en/contact/new-ts-request
