BBC Radio (4, 3, 2 and 5 Live) "Playback was interrupted or track failed to load" error (2022-12)
QNAP 451+
Intel Celeron J1900 (up to 1993 MHz (4 cores, 4 threads)
8Gb RAM
Current QNAP operating system
Plenty of disk space free
Single ethernet connection
Ubiquity Dream Machine router and gateway.
Ubiquity switches.
No VPN.
Wired ethernet
c40 Mbps download speed
Bluesound Pulse Mini 2i
Bluesound Node 2i
Ethernet wired connections
c5000 Tracks in the library
Linked to Tidal
For some months now I have had problems with BBC radio stations not starting or stopping suddenly. However, starting this week (posted on 23/12/2022) no stations will start at all.
The error message I receive is:
“Playback was interrupted or track failed to load”
Other radio stations work absolutely fine and start quickly.
The BBC Sounds App also works fine.
I am located in the UK and do not use a VPN for Roon.
Any thoughts would be welcome.
I have the same problem Ioading the BBC6 Music stream. Used to work fine, but now the link seems broken.
Thanks for any insight on the issue.
Jan
@Jan_Christiansen - What firmware version are you running on the QNAP? I’m on Firmware version QTS 5.0.1.2248 Build 20221215
John
Hi John,
I am running Roon Server 20220216 on my Sinology NAS DSM 7.1.1-42962 Update 2.
Kind regards,
Jan
RESOLVED:
Many thanks all. I manually installed ffmpeg as described in:
