BBC Radio 6 Music keeps dropping out after less than a minute and it’s happening on both an ethernet-connected device and also on 2 Sonos speakers. When I play other radio stations it doesn’t happen.
Also, if I stream to the Sonos speakers from the Sonos app (and not Roon) 6 Music plays fine. So it seems to be a problem of how Roon and 6 Music connect with each other. (I saw older posts of people have a similar issue but those threads are now closed.)
mjw
2
@Aqstr, to receive appropriate help, it would be really helpful if you could complete the template included in your opening post, and also provided below. Please be sure to include details of your core, network, storage location of your media files, and any messages displayed by Roon. Thank you.
<!‐-Include your operating system and machine info (Model, CPU, RAM)-‐>
<!‐-Write below this line-‐>
<!‐-Your network gear (model of routers/switches) and if on Wi-Fi/Ethernet, are you using VPN-‐>
<!‐-Specify what devices you’re using and their connection types, like USB/HDMI/Chromecast, etc.)-‐>
<!‐-Tell us how large your music library is, e.g. “30,000 tracks”-‐>
<!-‐Tell us about the problem you’re having in as much detail as possible. Screenshots are always appreciated!-‐>
Including these details in your first post helps resolve your issues faster.
Thanks, I’m goign to see if I can find an alternate stream for 6Music. Failing that I’ll use Sonos instead of Roon and come back to trying 6Music on it in a few weeks.
