Also, his mother (my sister) really wouldn’t notice stumping up $250K to clear his medical school debt. And before you make a comment, neither would I.
I generally make a point of not talking about money. All I was asking for was friendly recommendations from other people who enjoy listening to music. Lots of people obliged, for which I am appreciative.
I received a PM about this, so I checked the specs and found that this unfortunately does not work.
The A500 and A700 only has an analog XLR input, not the digital AES input for U1 MINI. As a DSP speaker, strangely the only digital input it has is WiSA.
To use a direct Lumin - Buchardt setup without going through the Hub, one will have to use a Lumin with analog XLR output such as D2 or T2. Although some may question the SQ impact of extra DAC - ADC conversion, I often read positive user reports especially from AV receivers and less expensive DSP speakers. And I’d prefer a cable connection to WiSA.
because I’m thinking also to use (in my main system there is Primare PRE35 in use, which can also act as an WiSA hub and can controlled serial and so I can add an additional hearing zone in another room) a pair of Buchardt A500:
You are meaning, that an analogue connection (with a Lumin D2 or T2) is the better solution than to use something connected to the hub?
By the way: Only in using the hub, you are able to use the room corrections from Buchardt.
