Best Ethernet Dongles to Use When Setting Up Pi Zero 2 W with RoPieee
Hi everyone,
I believe I am going to need an Ethernet dongle to set up a Pi Zero 2 W with RoPieee. Which Ethernet dongles work “out of the box” the RoPieee set-up process?
Thanks so much for your help.
R
About to release a version that supports a wireless installation… :crossed_fingers:
Wow, I’m very curious about how you’ve managed to do this :slight_smile:
When RoPieee detects there’s no connection, it will setup a wireless access point. You can connect to that (from your phone for example), select your wifi network in a webinterface and that’s it: RoPieee will reboot, connect to your wifi and continues it’s installation/setup.
This is wonderful news!
I would like to get an Ethernet dongle to have as a back-up option if the wireless network becomes unstable. Do you have any recommendations?
No I just use the one that came with my laptop. Most will do.
Thank you!
