Hi - I wish to move my Core from my iMac to a dedicated machine. I can pick-up the below quite cheap - what would be the best OS to run on it to get the best performance?
If you go with ROCK, just a couple of things:
Technically, the Intel NUC is the motherboard for it. The CPU is certainly good enough, but this might install just a bit differently than a typical NUC. I wouldn’t worry too much about that, but know it could be the case. A lot of people install ROCK on a lot of other motherboards (see “Tinkering” section).
You certainly need to upgrade memory to SSD for the ROCK OS.
I’m pretty sure the DVD drive will be inoperative with ROCK. But you can now plug in a USB CD drive if you need to rip CDs.
What are you calling ‘cheap’? Once you add in the cost of the SSD (~$100) and some RAM, a similar NUC might be comparable in cost.
I’ve run ROCK on less capable h/w without issue, several in fact, none were NUC, just don’t expect upsampling or extensive PEQ to work well. Extensions don’t run on ROCK so keep that in mind.
If it’s an Intel based chipset, ROCK should run fine. It used to run on my 4th gen i7 custom built pc ok before I upgraded my machine. I could upsample up to dsd128 no problems on that to. Nothing lost if it’s doesn’t mind you’ll know after a minute or so. If it all goes through at install then your all ok.
OK ,so what happened is that you put ROCK on the HDD as test and when that worked you put ROCK on an SSD for real use, but the HDD also still has ROCK on it.
I would disconnect the HDD (you’ve probably already done that) and bring up ROCK with SSD (you’ve probably already done that). Drop ROCK, leave the SSD as boot drive (as it probably is now), reconnect HDD and bring ROCK backup
The kernel panic is because of a missing file. Maybe this approach will clear it out.
If ROCK does come up then reformat the HDD to get rid of any old ROCK installs.
That’s pretty much it - I also swapped the SSD to SATA 0 and HDD onto SATA 1 but still got kernel shizzle so disconnected the HDD and now I’m happy with SSD but unsure how to format HDD?
