So I currently run a IntelNUCi7 (16GBRam, 512GB NVM Drive) with Windows 11 for both my HQPlayer Desktop and Roon Server installation.
I am almost 100% using streaming services (TIDAL) for music playback via Roon.
In HQPlayer I am currently only using PCM filters/playback as I never got DSD to work reliably. (Negligible CPU load with any PCM filter combo)
It is (Intel NUC with Windows,HQPlayer, Roon) currently connected via USB-C to a “SMSL Po 100 Pro” which in turn is connected via HDMI (IIS) to my “Gustard R30”.
Apart from that I also own an unused Intel Nuci3 (8GB Ram, 128GB SSD).
My Gustard R30 has a NAA endpoint built in that could also be used.
And it also has a USB in port that could be used to connect directly to the Intel NUC’s.
I am considering the following, installing HQPlayer embedded/OS on one of the Intel NUC’s instead, and ROON Core on the other Intel NUC (Not sure which one for what application).
Would that be recommended instead of my current setup?
NUCI7 + “HQPlayer” AND NUCi3 + “ROON Core”?
NUCI7 + “ROON Core” AND NUCi3 + “HQPlayer”?
”Current setup” (NUCI7 + Windows + HQPlayer Desktop + Roon Server)
Follow up question, which connection would be the “better one”,
HQplayer NUC - via USB to Gustard R30
HQPlayer NUC - via USB to “SMSL Po 100 Pro” to HDMI to “Gustard R30”
HQPlayer NUC - via NAA to “Gustard R30”
Thanks for reading this far ![]()
