Hello i recently installed roon. I have a bluesound pulse mini 2 and a node 2. Also attached is a marantz surround sound receiver. The core is installed on a network laptop that is permanently hardwired and generally not very used. It is running on windows 10 64 bit pro. the computer is a thinkpad, 8gb ram, 2.2 ghz.
PROBLEM: the node and pulse mini when syncronized dont actually sync. the node is hard wired. They occasionally sync up but then often loose sync. sometimes the pulse disappears altogether for a while.
What suggestions do you have to facilitate the two devices actually syncing? @support
Unfortunately this is a known issue with Bluesound, appears to specifically affect the Node. A fix has been talked about by Bluesound for a year or so but has yet to materialise. Plenty of posts on the forum if you have a search.
I think I fixed it.
Using the bluesound app I synced my devices as one group, then deleted and added the one unit in room. I just can’t vary volume from one roon to the other with out opening the bluesound app.
That will work for Bluesound as it’s not Roon doing the sync so your good. Unfortunately not when syncing to other RAAT devices which should also sync but don’t.on Bluesound.
I changed my Node 2 last night to be the priority clock and used that as the controlling endpoint, it was slightly out at start but within 30 secs or so stayed in sync with my Atom. May have to experiment a bit more.
Just got this back from Bluesound support. I won’t hold my breath. That’s two things now I have outstanding on the one device that I bet don’t get sorted now the 2i is out.
Hi Simon,
Indeed, this is something we’re looking into from other reports.
Unfortunately, we have no solution for this in support - but you can try rebooting the Bluesound player and the router.
I don’t think te problem is limited to the Node. I don’t have one, only two Flexes and one Mini. But I do have a synchronisation issue. To the best of my knowledge, the core problem has not been fixed yet.
Ah, fair enough…it seemed to be a common factor, as there seemed to be some w/o a Node that are managing synchronised play, but I was making quite an assumption.
Somewhere around on the forum there’s a message from either Danny or Brian explaining the context to this. IIRC, and I don’t want to misrepresent them, it basically said it was early days and consequently a QA mistake that would not be repeated.
Yes, it’s not entirely limited to a Node2.
I had a Vault2 and PowerNode2 that synced perfectly together for two years.
After selling the Vault2, I have yet to get any Bluesound, or other Roon endpoint to sync properly with the PowerNode2.
