Bluesound Node Audio Dropout & Static
MacOS Vntura
Mac Mini M1 8GB RAM
1GB Ethernet
TP Link Archer AX53 Router
Bluesound Node (N130)
Topping E50 DAC
Cambridge Audio CXA80 Int Amp
100,896 Tracks
Bluesound Node connected to Topping E50 DAC via USB - Severe audio dropouts and static. If connected via COAX or Optical no issues present. It appears that this is a known issue between Roon and Bluesound. Can you let me know whether a fix is coming soon for this issue? I see from other forums, Bluesound believe the issue rests with Roon. Many thanks.
Hi @Soul_Bruva,
There is indeed a known issue with using a node via USB. At this time there is no word on when a fix will be released from Bluesound.
Regards,
Wes
Return the node…get a raspberry pi4 :slight_smile:
