Build 88 - not possible to add albums
I just attempted to add two new DSD albums and for some reason they do not show up in ROON even if the setting is that ROON should identify new files immediately. Wonder what the problem is??
@rasmussenmorten Did you try forcing a rescan of the folder?
Russ
No, because I feared that function would recount all the albums - and normally when that happens one have to delte all the duplicates from tidal once again…
What format are the files?
They are DSD files
What format are the files? DSF, DFF, ISO, DoP-FLAC, other?
I solved it. Somehow the folders would not give access to me on my mac mini…
