The display of the aries doesn’t give right info anymore.
When i play music i see a pause or play indication and the track progress bar does nothing.
With build 94 of roon it works fine.
I have noticed that when I play an album from Roon that the Aries display looks like it’s paused at 0/0 and I can’t control it with the Auralic remote. Other times it shows the current track playing and I can start/stop. Anyone experience this or have an explanation?
We’ve heard some reports. Unfortunately, our in-house Aries is having a hardware issue that’s preventing us from investigating this problem, and we’re waiting for a replacement unit (it shipped out late last week).
As soon as it arrives, we’ll get this sorted out. Something about how the Aries is processing messages from Roon that relate to the front panel + remote control is going wrong, but we need to investigate further to determine whether the fix will be on our end or theirs.
The problem seems to have begun with Build 99, which suggests that we caused it, but I’m having trouble seeing how that could be based on the changes we made. Once the replacement device is in our hands, all will become clear.
We received the device and got it powered up over the weekend. While the problem is easier to reproduce with Build 99, it can be reproduced with older builds too. The issue appears to be on the Aries side.
We’ve made a report to Auralic that explains the problem and our investigation. They are generally very responsive in these situations, though I don’t know exactly when they next intend to release a software update for the device.
I did and I can confirm that the display is perfectly in sync with Roon now. In general there seem to be performance improvements. No difference in SQ in my environment.
I am on build 102 and just discovered my Aries display is having problems. I assume it’s just a coincidence but mine is just dimmed and uneven, the content (where I can see it) seems fine. Reset the display twice and no joy, so I sent them a support note. I didn’t mention about Roon though, perhaps I should have.
