Hello,
As this post stated (Roon Partner Update: September 2019 - Roon Labs) the Cambridge Audio CXA81 is Roon Tested. If I got this right, it means that if I use a USB streamer like Pro-Ject Stream Box S2 Ultra (roon ready) to feed the amp, I should “see” the pair in roon natively.
There is a question wich I cannot answer tho: the USB volume control is supported like the pro-ject maia DS2 (if I move the wheel the change of volume is displayed in roon) or are the 2 volume separates?
Thank you
