Meridian 218.
I can not connect to Meridian Audio 218. ROCK is are on the same network.
I have rebooted several times with no avail.
The 218 light shows same as Sooloos (Net) but it does not shows in the settings audio.
No sound at all.
Hello @the5rs, and thanks for your report! I spoke to the team about this thread and they asked me to gather more information about your network topography. Could you please elaborate on what router you’re using, if there are any switches, and how your devices are connected? Thanks!
Hello @the5rs, I tried to enabled diagnostics on your core, but I’m not getting a response. Could you please turn it on so it can upload the report? Thanks!
Hello @the5rs, the team got back to me and they wanted to know if you could test this with the MacBook pro as the core temporarily with the following steps:
Hello @the5rs, I verified that our in-house 218 isn’t experiencing this issue, do you have another router you could try temporarily as a test? Let me know!
