*Core Machine (Operating system/System info/Roon build number)
Roon Nucleus/build 537
Gigabit Ethernet
Chord Hugo 2 and Chord 2Go dedicated streamer for Hugo 2
Please see the first google drive link. The Screenshot video will show that the Hugo 2 says ‘not certified’. The Chord 2Go, although a Roon approved product, is not in the list to choose from. It only shows at the bottom on the audio tab for Airplay. It appears these devices are not set up properly.
https://drive.google.com/file/d/1DXcpgrySW7yOc3HlapJVCuaUnKTenGXL/view?usp=sharing
The second link shows a picture of the audio flow in roon and it shows USB as the final connection. I have the Chord 2Go wirelessly streaming to headphones that are directly plugged in to the Hugo 2. The 2Go and the Hugo 2 are attached together. The Blue dot next to the Volume indicator shows some kind of disruption in the flow?
Thank You!
