I understand the best signal path for the TT2 is via the two BNC inputs.
What SPDIF converters do people out there use and what converters are recommended?
In anticipation Rob
In anticipation Rob
It really depends on what you are connecting to, but BNC - RCA typically…
It’s preferable to avoid converters but there are lot’s options, many cheap enough to try out from Amazon, a quick search will help…
BNC to BNC only
I dont think you’ll find many DDC’s that provide a Dual Coaxial output suitable for the TT2, other than the MScaler that is…
If you are only concerned about 24/192PCM and DSD64 i suppose you could use any impedance matched cable.
I would seriously consider the compatibility and flexibility of the USB-interface though. And, don’t let anyone tell you what “sounds best”, only you can decide that.
