Eero mesh 1 router, two beacons. Mac connected to router via ethernet cable.
My Mscaler is connected to my Dave via BNC1 and my Macbook Pro connected to the Mscaler via USB.
I have lcd4 connected to the D.
My Chord Mscaler is identified on Roon but on the signal path it should be feeding my DAVE via BNC1 output but the DAVE icon isn’t showing up on the signal path, only the HMS does! Does the Mscaler icon like contains the DAVE in it?
I remember seeing before the Cord Dave and than my Audeze, but now my signal path is showing only the MQA core on my Mac if Im streaming a MQA file via Tidal masters and the Mscaler icon.
Please advise how to setup it correctly in order to see the signal path right.
You can switch the zone icon from the M Scaler to the Dave in the “Device Setup” screen for the zone. Click on the “Not your device?” button and then select the Chord Dave in the device browser, making sure to click “Save” before exiting the “Device Setup” screen.
You will not be able to have the M Scaler and the Dave appear in the Signal Path at the same time.
thank you very much john!
much appreciated,
what are you suggesting then ?
if i have an mscaler hooked up to DAVE should i rather setup identified
chord device as mscaler or dave for optimum performance and quality ?
what should i choose ?
now it is setup as M scaler
but behind the icon there is a device with its own and unique setup.
the M scaler now is “ Roon tested” which means “ maximum compatibility”
if its just an icon why it went into roon tested process
i am missing something here😟
