Chord Qutest/Rasberry Pi not working with Curious cable
Qutest’s USB input is galvanically isolated.
Non-USB 2.0 spec cables can have issues in general but sometimes more with isolated DAC USB inputs.
The Schiit Modi’s USB input isn’t galvanically isolated.
If you add an ISO Regen you may run into issues with your Curious, with your Mac.
Stick to USB spec cables like this (ask Rob Watts, not John Darko what he thinks of this cable vs Curious):
https://www.amazon.com/Tripp-Lite-Hi-Speed-Ferrite-U023-006/dp/B003MQ29B2/r
was that cable recommended by Rob Watts? Or maybe he just recommends the one he includes with the qutest?
As I mentioned, ask Rob?
I think Rob recommends certified cables like included in the box and like I linked.
Perhaps the bits flow into the bitbucket in the opposite direction… :sunglasses:
Has anyone compared the Qutest connected via AES/EBU over a coaxial line on the BNC port to a USB connection?
